Arclength method with gravity and hydrostatic pressure
    • corne
      Dear,
      I have an analysis with post-buckling behaviour in workbench 2020R1. For this analysis I need to use the arclen method. For my pressure load I need I have to set the "tabular data - Independent variable" to step instead of time.
      But I also need to consider gravity and hydrostatic pressure. These two loads are going from 0 to full in the first time step and remain the same in the second time step. It is in this second time step I need to use the arclen method. I hoped that because the gravity and hydrostatic pressure loads don't change in this second load step, it wouldn't be an issue with the arclen method. However it is.
      Is there a way to combine these loads with the arclen method or is there a workaround somehow?
      Thanks in advance for your reply.
Viewing 0 reply threads
