April 19, 2022 at 4:25 am
El_Manguangua
SubscriberHi! I hope you are all doing great!
I'm working on a project in which I have to study The FSI (Fluid-Solid interaction) Between air and an aircraft wing. The interaction occurs specifically between air and the skin of the wing, I'm attaching a picture of said skin (it has been meshed already):
April 19, 2022 at 3:57 pmVigneswaran Sridharan
Ansys EmployeeHey You could also use Shell/3D surface elements (Like Shell181, Shell281) with mid-surface extraction in SpaceClaim (Refer toMidsurface tutorial (spaceclaim.com)).
But, keep in mind you cannot generate a Midsurface unless the faces have a constant wall thickness. In SC, the Midsurface tool will not select the non-parallel faces.
Nodes on Shell elements have 6 Dof's. Hence MPC based bonded contact should be used to connect shell and solid elements.
Refer to this video for more info on understanding shell elements.
Vigneswaran
Ansys Help
Rules & Guidelines ÔÇö Ansys Learning Forum
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
