June 30, 2022 at 5:49 am
satya_ss
Subscriberhow to add areal density for a steel plate while doing simulation. for example, a steel plate with a thickness of 6mm and an areal density is 4.7gm/cm2.and what is use of areal density
June 30, 2022 at 6:11 am
Charudatta Bandgar
SubscriberHello Satya Sundar
Which discovery product are you using and what is the exact requirement. Areal density is not possible in discovery, but I can see if there is a workaround to use it.
Regards.
June 30, 2022 at 6:45 am
satya_ss
SubscriberHello sir, thank you for your response. I am doing an air blast on a steel plate using Ansys Autodyn software. In the paper, steel plates are used as a shell solver .and areal density is assigned for it. So how to implement areal density on the plate while density is given
June 30, 2022 at 7:49 am
Charudatta Bandgar
SubscriberSatya Sundar
Regarding your question on Ansys Autodyn, please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Thank you for your understanding!
Regards.
3930
2649
1861
1272
610
