Arnab Chakraborty
    • cnac
      Dear All
      I am trying simplified micro-model for a masonry wall in ANSYS Workbench. I am using Frictional Contact between the Masonry element with following properties:
      E = 9250 N/mm2
      Coeff of Friction = 0.6
      Normal Stiffness, FKN = 1.0
      therefore programme is calculating Normal Stiffness = 9250 N/mm2
      However the programme also assigning the Tangential Stiffness, FKT = 1.0
      hence the tangential considered for the analysis = 9250 N/mm2
      How do I change the FKT = 0.5? in Workbench.
      Any help will be very much appreciated.
      Kind regards
    • Aniket
      Please check if the following thread helps.
      https://forum.ansys.com/forums/topic/increase-contact-force-reaction-czm-mode-ii/
      basically you need to use rmodif command in a command snippet under your contact
      more info at
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_ctec/Hlp_ctec_realkey.html
      -Aniket
    • cnac
      Thank you, I have managed to model with RMODIF.
      I want to model this separation using ANSYS contact
      Actual scenario
      However, I am getting a convergence problem and can only get
      Partial Output
      i.e., no separation is obtained, only sliding is occurring.
      Any help will be greatly appreciated.
      Kind regards
    • ajaygawde
      My project on coupled filled structural analysis of hot box of pressure vessel. i have error in structural analysis about stress plots in ANSYS APDL. Error message is " the requested data s is not available, the plnsol commanad is ignored. Can anyone help me.
    • Aniket
    • cnac
      Hello Aniket
      you mean this one
    • Wenlong
      Hi cnac,
      I agree with Aniket that cohesive contact debonding should be able to model such behavior. You can assign bonded contact between the mansory and the contact behavior is controlled by traction-separation law. And the contact will be deactivated to allow cracking when the failure criterion is met in the cohesive law. (More info can be found here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_thry/thy_mat11.html?q=cohesive%20debonding)
      I've done similar research by applying cohesive elements to every element boundary to model concrete cracking, and below are some images.
      Wenlong
Viewing 6 reply threads
