September 13, 2019 at 9:03 am
arunsp453
SubscriberIn the ansys solver I defined time step size as 0.001 and asked the software to save data of velocity filed for every time step. As a result of this I am able see 1000 .Dat file. Now I would like to play with those data in MATLAB to analyse the dynamics of flow. when I click on the .Dat file which is of zip file, a kind of fintgz file will be seen from which I am not able to flush out the data. So any body can help me how to extract .dat file in MATLAB to do dynamic analysis??
please find the supporting images
September 13, 2019 at 9:33 am
DrAmine
Ansys EmployeeCan you please insert screenshots here: ANSYS STAFF do not download attachments. Which software are you using? And why you are unarchiving the data file? Anything related to MATLAB that is the wrong Forum for that.
September 13, 2019 at 12:35 pm
September 13, 2019 at 12:36 pm
arunsp453
SubscriberI am using Ansys fluent, I need those data in matlab so i would like to know about the procedure to extract.
September 13, 2019 at 1:08 pm
DrAmine
Ansys EmployeeBest to save the Files in Fluent without the".gz" format (that means in legacy *.cas and *.dat files). But the question is what does Matlab require? Do you want to extract some informations from Fluent and read it into Matlab? I guess via dat files is the wrong way. But as I said that is the wrong forum for that!
September 13, 2019 at 1:41 pm
Ansys EmployeeIf you want the data for something else, you can (probably) export an ASCI format, or write out an interpolation file from Fluent (avoid binary unless you like programming). Unless you want to try and figure out then write a reader for Matlab: note you need to review the contents of a case & data file, the latter isn't going to be much use without the former.
September 14, 2019 at 11:19 am
September 21, 2019 at 4:03 am
arunsp453
Subscriber@rwoolhou.
I am able to get the format which I was desired. so 'export during calculation' in ASCII format helped me to get a file that I can open now in note pad.
thank you
2524
2066
1279
1096
457
