November 14, 2019 at 11:26 am
Edmundo
SubscriberHello, my question is related to meshing the assembly model I have imported to ansys.
I intend to perform a flow simulation in a pneumatic hammer where the piston will move due to an opening valve and I would like to observe the drop of pressure due to this volume increase.
I have imported three different assembly files so far (IGES, STEP, and Parasolid).
Once I check geometry I see the model is a solid one but when I open the meshing, the model becomes a shell and it gets a bit harder for me to describe the boundary conditions. is there any solution for this problem?
and regarding my specific simulation as described in the first paragraph. Would fluid flow (fluent) be the most adequate simulation I should use to perform such an analysis?
Thanks in advance.
November 14, 2019 at 11:30 am
Ansys EmployeeIf you're reading into SpaceClaim and it's a solid body that should carry into meshing. Can you check the initial translation has been successful? Images of the bodies in the left hand panel will be helpful.
Compressible liquids are complex, so yes Fluent will handle them but you'll need to be careful.
November 14, 2019 at 12:10 pm
November 14, 2019 at 1:21 pm
Ansys EmployeeDeselect the Section plane, and also expand the "geometry" bit in Meshing. I think you've just misunderstood the display.
November 14, 2019 at 2:36 pm
Edmundo
SubscriberThank you for your attention and support Mr. Rwoolhou
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5364
3363
2471
1310
1018
