September 3, 2018 at 3:12 pm
jonsys
SubscriberBecause of parametrizing my CAD geometry in DesignModeler, I am using formulas. Under Parameters>Parameter/Dimension Assignments I want to apply this formula for one of the variables:
L and R are known and represent lengths [mm]. For sin^-1 I use the asin(arg) function. I want to get the asin(arg) value in radians but I guess something is being messed up with degrees.
That is how the expression looks like right now: @L-@R*(2*asin(@L/2/R)-1)
How should I write it?
September 3, 2018 at 4:27 pm
SubscriberThe output of asin is in degrees, so just divide by 57.29578 to convert to radians.
September 4, 2018 at 1:54 am
September 5, 2018 at 3:24 pm
jonsys
SubscriberPeter, kkanade,
thank you. now I understand that the result was in degrees. Does it allow PI constant to be used directly?
September 5, 2018 at 9:29 pm
SubscriberI don't think there is a predefined variable for pi, which is why 180/pi equals 57.29578 is used above.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
