Photonics
Photonics
Ask: How to draw an arc with a right-angled trapezoid in cross section through code?
    • phill
      Currently through addpoly; draw the arc structure. Below is the code and graphics
    • Greg Baethge
      Thank you for posting your question. I think you should be able to create such structure using a planar solid object. It's a bit tricky, as you have to:
      divide the structure in n facets each made of 4 vertices.
      define all the vertices needed to define the facets (there should be 4*res vertices, that can be defined in a similar way as in your current code)
      connect the vertices to create the facets (there should be (res-1)*4+2 facets to cover front, back, top, bottom and sides)
      the latter is usually the painful part! We have this example that could be helpful:
      Drawing truncated cone in finite element
      Let me know if you run into any issue.
    • phill
      thank you for your reply. The solution you gave seems to be a bit difficult. If you can solve this problem through ÔÇ£addpolyÔÇØ, thank you.
    • Greg Baethge
      I definitely agree it's not simple. The limitation of addpoly is it can only create a shape that is extruded in the z direction, so it can't have any angle in the vertical walls. I had a bit of time, so I wrote this script:
      ## Definition of the vertices coordinates
      z_bot = matrix(res);
      z_top = z_bot + thickness;
      x1_top = rad1 * cos(t1);
      y1_top = rad1 * sin(t1);
      z1_top = z_top;
      x2_top = rad2 * cos(t1);
      y2_top = rad2 * sin(t1);
      z2_top = z_top;
      x2_bot = rad2 * cos(t1);
      y2_bot = rad2 * sin(t1);
      z2_bot = z_bot;
      x1_bot = (rad1 - thickness*tan(thetarad)) * cos(t1);
      y1_bot = (rad1 - thickness*tan(thetarad)) * sin(t1);
      z1_bot = z_bot;
      x = matrix(4*res);
      y = matrix(4*res);
      z = matrix(4*res);
      x(1:res) = x1_top; # top R1
      y(1:res) = y1_top;
      z(1:res) = z1_top;
      x(res+1:2*res) = x2_top; # top R2
      y(res+1:2*res) = y2_top;
      z(res+1:2*res) = z2_top;
      x(2*res+1:3*res) = x2_bot; # bot R2
      y(2*res+1:3*res) = y2_bot;
      z(2*res+1:3*res) = z2_bot;
      x(3*res+1:4*res) = x1_bot; # bot R1-angle
      y(3*res+1:4*res) = y1_bot;
      z(3*res+1:4*res) = z1_bot;
      vtx = [x,y,z];
      ## Definition of the facets
      fct = cell((res-1)*4+2);
      for(i=1:length(fct)){
      fct{i} = cell(1);
      fct{1}{1} = [1, res+1, 2*res+1, 3*res+1];
      fct{2}{1} = [res, 4*res, 3*res, 2*res];
      for(i=1:res-1){
      j = i+2;
      fct{j}{1} = [3*res+i, 3*res+i+1, i+1, i];
      fct{j+res-1}{1} = [i, i+1, res+1+i, res+i];
      fct{j+2*(res-1)}{1} = [2*res+i, res+i, res+i+1, 2*res+i+1];
      fct{j+3*(res-1)}{1} = [3*res+i, 2*res+i, 2*res+i+1, 3*res+i+1];
      addplanarsolid(vtx, fct);
      Where thetarad is the angle of wall in radian, rad1 and rad2 the 2 radii (taken from the top surface). This should create a object like this:
      Let me know if you have any question
    • phill
      Thank you for taking the time to help, the problem has been resolved. I may need your help if I face difficulties.
Viewing 4 reply threads
