October 11, 2018 at 3:23 pm
wayne.rumsey
SubscriberI am attempting to learning Discovery AIM by replicate a wind tunnel with the ASMO vehicle. In the AIM tutorials or App (ie Wind Tunnel) I have reviewed the enclosure domain is small compaired to what I have used in other CFD software.
- Is there a recommended distance from inlet to vehicle and vehicle to outlet?
- Is there a recommended blockage factor for the x-sectional area of the enclosure?
- I have used 3X vehicle length for inlet and 8X for outlet.
- With 5% x-sectional area blockage factor.
- Intel velocity magnitude of 50 m s^-1
- Outlet gauge static pressure of 0 Pa
- For the walls and top of the tunnel a flow specification of: Free Slip
- For the floor of the tunnel a flow specification of: No Slip, moving at a magnitude of 50 m s^-1
- K-Omega SST for RANS Model
- I am monitoring Force.x and have run the analysis up to 2,000 iterations.
Medium solution fidelity:
High solution fidelity:
I am finding as I increase the solution fidelity the drag (Force.x) as shown above in the chart increases in variation, appearing less stable.
- I am attempting to find a converged solution but not sure what else to try?
October 12, 2018 at 6:56 am
Naresh Patre
Ansys EmployeeHello WRumsey
I will contact you separately for requesting the file.
October 16, 2018 at 2:23 pm
Naresh Patre
I tried changing some solver settings and mesh settings but though the convergence plot and drag values are stable, the model is still not converging. I will continue working on it and will update you.
October 16, 2018 at 2:33 pm
wayne.rumsey
SubscriberNaresh,
Thank you for the status update, I have continued working as well, without success.
Any general guidelines on:
- Recommended distance from inlet to vehicle and vehicle to outlet?
- Recommended blockage factor for the x-sectional area of the enclosure?
- Is there a way to define mesh refinement zones around the vehicle or in the wake behind the vehicle?
Best regards,
WRumsey
October 19, 2018 at 9:27 am
Naresh Patre
I have passed on the model to development team and will let you know their suggestions.
Regarding your questions:
- Recommended distance from inlet to vehicle: 3X vehicle length
- Recommended distance from outlet to vehicle: 5X vehicle length
- Recommended blockage factor: I am not sure about the factor but generally the width and height of tunnel can be considered as 2 times the vehicle length.
- Currently, there is no option to define mesh refinement zones. One workaround here is to split the fluid body into appropriate sections which resemble refinement zones and specify body sizings.
3720
2570
1783
1236
594
