October 25, 2023 at 11:24 am
Aras karimi
SubscriberI am creating a hexahedral mesh on a 3D airfoil in ICEM. I checked the aspect ratio of the grid, which reported values of 1-31500, which is a very high number and shows most of the very large elements produced behind the airfoil.
Should its values be reduced? and how ?
Is it necessary to create a smaller block near the airfoil?
Regards.
October 27, 2023 at 1:56 pm
Essence
Ansys EmployeeHello,
You can try to increase the number of divisions horizontally. This can also reduce the AR.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
