Photonics
Photonics
Aspherical surface in Lumerical FDTD
    • Yuan0710
      Dear all,
      Recently, I want to create an aspherical lens in Lumerical, and the formula follows extended asphere
      https://neurophysics.ucsd.edu/Manuals/Zemax/ZemaxManual.pdf (page 298)
      However, the schematic of the surface is quite different from the Zemax.
      I also used python to check the surface, and here is my code:
      C2=-579.0611352914399
      c2=-7.810334943869855E+003
      z2=1/C2*r**2/(1+np.sqrt(1-(1+c2)*1/C2**2*r**2))
         -6.754857777025000E-001*(r/cab)**4
         -1.806357591187000E-001*(r/cab)**6
         +1.771543787203000E-001*(r/cab)**8
         -2.757627677274*(r/cab)**10
         +4.527528774838001*(r/cab)**12
         -2.658990544222000*(r/cab)**14
         -9.080232875091999E-1*(r/cab)**16
      plt.plot(r,z2)
      plt.xlabel("radius")
      plt.show()
      The correct aspherical surface should be :
    • Greg Baethge
      Thanks for posting on the forum. Could you check the x span and y span defined in the "Geometry" tab? They should be large enough to cover the full width of the lens. I ran a quick test, it seemed to work:
      I only copied and pasted the custom term from your post.
    • Yuan0710
      This is my current geometry setting but the schematic is wrong.
      However, it is strange about the results of the aspherical surface.
      Recently, I successfully used "import surface" to establish my aspherical lens, though.
      Sincerely
    • Greg Baethge
      I have to admit I've never really used this surface object. I'm more familiar with the surface import, that would have been an alternative I would have suggested.
Viewing 3 reply threads
