October 9, 2021 at 3:12 pm
oss7m
SubscriberI'm trying to assign a band for the motion of the two rotors in Axial Flux Generator that are separated by the fixed stator.
The problem is that I can't contain the two rotors in single band due to the configuration of the machine and I can't exclude the stator from the band either.
Any idea of how I can do this?
October 11, 2021 at 10:35 amNavya C
Ansys EmployeeHi @oss7m You can apply two bands and still get the result.
Refer to the below forum discussion.
apply motion for double rotor ÔÇö Ansys Learning Forum
Regards Navya
October 11, 2021 at 8:14 pmoss7m
SubscriberI solved the problem by Uniting the two bands into one geometry.
Thanks for your help.
February 16, 2022 at 9:41 amViewing 3 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
3756
2573
1823
1242
598
