October 26, 2023 at 11:33 pm
Alaeldin Eltayeb
SubscriberHi, my issue I guess it is super simple. I am not able to assign materials for the geometries I uploaded. If I am sketching new parts, then it is okay to assign materials, but not when a ready-made piece is being uploaded. I am using 2023 R.
Note: Under the tree, there is a solution, and I should be able to select the materials I added in the first step (engineering data). Please send me a solution via email if possible.
eltayeb@pdx.edu
let me know if you need more information.
Best,
Alaaeldin Eltayeb
October 27, 2023 at 2:07 pm
Ashish Khemka
Forum ModeratorHi Alaaeldin,
We cannot support you via email. When you sketch a new part and update your geometry then you can change the material assignment in Mechanical. The material should be defined in Engineering Data. If the issue is different then please share snapshots as well as it may provide more clarity.
Ashish Khemka
October 27, 2023 at 4:59 pm
October 27, 2023 at 5:01 pm
Alaeldin Eltayeb
SubscriberAshish Khemka you can tell that I cannot see where to assign materials. Please, your input is highly appreciated.
October 27, 2023 at 6:05 pm
October 27, 2023 at 6:48 pm
October 27, 2023 at 6:50 pm
October 30, 2023 at 8:56 am
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3155
1688
1478
