February 24, 2022 at 3:23 am
Zhen_Hao
SubscriberHello everyone,
I want to assign relative density to my cube in ANSYS Workbench. Can I know which method can help?
February 24, 2022 at 3:59 pmAshish Khemka
What is the analysis you are trying to perform? Please elaborate.
Regards Ashish Khemka
February 24, 2022 at 4:17 pmZhen_Hao
My project is to simulate a sintering process of an FDM printed cube using ANSYS, and I have successfully performed a cooling process of a cube (100%)by using transient thermal analysis. Right now, I would like to generate pores that formed after debinding on the cube and rerun the cooling process. Currently, I am trying to assign the relative density, 0.8, for the cube so that it is like having 20% porosity in the cube. Can I know that is ANSYS able to do that?
Thank you.
Regards Zhen Hao
February 24, 2022 at 5:35 pmAshish Khemka
Please see if the following discussion helps:
Constitutive Modeling of 3D Printed FDM Parts: Part 1 (Challenges) ÔÇô PADT, Inc. ÔÇô The Blog (padtinc.com)
Constitutive Modeling of 3D Printed FDM Parts: Part 2 (Approaches) ÔÇô PADT, Inc. ÔÇô The Blog (padtinc.com)
February 24, 2022 at 5:39 pmZhen_Hao
SubscriberThank you so much for the info!
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2524
2066
1279
1096
457
