Assign steel Fibers materials on Concrete Cylinder.
    • nevertrust
      I am trying to verify experimental data ( Load Vs deflection graph) with simulation results.
      Length of steel fiber   Lf = 60mm (End hooked type)
      Diameter of steel fiber Df = 0.75mm
      Density of fiber ? = 0.0781 g/cm3
      Volume percent of steel fibers (V) = 4%
      Orientation of steel fibers is random
       Dimension of Cylinder dia 100mm X 200mm
      How can we simulate such type of model?
      Waiting for Positive response.
      Thank you.
    • Wenlong
      Hi nevertrust.
      You can use Ansys Material Designer to find out the equivalent homogeneous material property of the fiber-reinforced concrete. A detailed post about Material Designer can be found here: https://studentcommunity.ansys.com/thread/material-designer-introduced-in-19-2/?order=all#comment-98cbb0ab-2e10-462b-9884-a96f002dd0de
      Wenlong
      Useful Links
    • nevertrust
      Thank you Wenlong for your reply.
      I use ANSYS 18.1 but didn't find ANSYS Material Designer.
      Do I have to use some extension or version should be upgraded?
      In Post 19.2 was used.
      Thank you.
    • Wenlong
      I am not 100% sure but I think Material designer was added only recently like after 2019R1. So please use the latest version of Ansys.
      Wenlong
Viewing 3 reply threads
