May 18, 2020 at 6:56 pm
emartell
SubscriberI am using ANSYS Mechanical to model a mask pushing into a face to understand how the face deforms with the mask application. I want to assign different material properties to different regions of the face mesh to accurately capture the different skin stiffness at different locations on the face. For example, the material properties around the nose area are much stiffer than those in the cheek area. The picture attached shows an area where I want to have a different material assignment.
I have no idea how to do this in ANSYS, I have only able to assign one material to the entire mesh. Any help would be appreciated, I am not particularly experienced in ANSYS.
Thanks in advance!
May 20, 2020 at 9:16 am
Aniket
Ansys EmployeeAnsys staff can not download images on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline.
Also, you need to split the geometries into multiple bodies in order to apply a different material to each. All the different bodies can still be in a single part with shared topology so they share nodes at the interface.
-Aniket
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2656
2120
1347
1118
461
