Assigning parameter in worksheet
    • Timo Mueller
      Hello!
      I'd like to assign a parameter in the worksheet for named selection.
      For example add or filter nodes equal to -parameter P1-.
      See uploaded file.
      Any ideas?
      Thanks in advance and best regards
      Which package would this apply to?
    • Sandeep Medikonda
      Hi Timo,
      Does this article from the docs help?
      ~Sandeep
    • peteroznewman
      Timo,
      When the Named Selection worksheet needs a value, it seems it will only accept numbers. I couldn't find a way to type a Parameter name.
      In other words, the field has input validation checking that only accepts numbers.
Viewing 3 reply threads
