Associating a part geometry to a named selection via Scripting
    • thermalsr71
      First time in this forum. I want to do a script that associates a part geometry from the Geometry tree to a named selection. It looks auite simple at first sight.
      Here's my script.
      model = ExtAPI.DataModel.Project.Model
      geom = model.Geometry
      selection_manager = ExtAPI.SelectionManager
      for part in geom.Children:
          bodyName = body.Name
          selection_manager.ClearSelection()
          selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
          selection.Ids = [part.ObjectId]                                          ! at this point, I associate my part ID to the selection
          selection_manager.NewSelection(selection)
          new_namedSelection = model.AddNamedSelection()
          new_namedSelection.Name = 'b_'+body.Name
          new_namedSelection.Location.Ids= selection.Ids           ! HERE IS THE PROBLEM
      The problem here is that if I do a print(selection.ids), I'll get the Id associated to the part I want the named selection to be associated to. So far so good. But if I do a print(new_namedSelection.Name.Location.Ids), I'll get an empty list, when it should be a one-item list with the Id I'm interested in.
      I don't understand why the last line does not work properly.
      Thank for your time
    • Erik Kostson
      Hi
      This post is relevant.
      https://forum.ansys.com/forums/topic/act-script-assign-items-to-a-named-selection/
      All the best
      Erik
    • thermalsr71
      Hi Erik,
      The GetGeoBody() was what I was missing. It worked.
      Thanks
    • Erik Kostson
      Yes we need the body id to define the NS. Great that it worked. Erik
    • thermalsr71
      However, is there a method  similar to NamedSelection.Location.Ids that gets the ids of the nodes associated to the name selection geometry, instead of the ids of the geometric entities?
      Thanks in advance
Viewing 4 reply threads
