3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Associativity in Spaceclaim/Discovery assembly
    • avlahinos
      I have two spaceclaim parts and bring them in a new part/assembly using insert geometry.  When the original part is modified the assembly part does not update. Is there any way to update the assembly geometry?
    • Subashni Ravichandran
      Forum Moderator
      Hello Andreas
      Can you please confirm that both files are saved after modification?
      Forum Moderator
      Hello Andreas
      It is currently not possible to update directly. You will have to reimport the geometry that is modified and saved.
