3D Design
3D Design
Atrium modeling
    • Afifyhend
      Hi, I'm trying to study the airflow in a building through atrium. But the geometry always form one body without the inner walls and floor slabs n
    • peteroznewman
      Which CAD program are you using to edit the geometry?n
    • Afifyhend
      I'm using spaceclaim from ansysn
    • peteroznewman
      There is a No Merge button that you should click on the left when you do operations such as Pull to prevent bodies in the same part from merging.nIf you reply with some screen shots, we may have more suggestions to help you.n
    • Afifyhend
      Thank you that was helpful n
Viewing 4 reply threads
