September 20, 2022 at 10:18 am
bublee-2016114988
SubscriberHow do I simulate a nanoparticle adsorbed onto a waveguide? How do I calculate the correct position for the np? Please help.
September 20, 2022 at 5:33 pm
Guilin Sun
Ansys EmployeeI think there are different ways to calculate the nanopartical absorption:
1: calculate the loss of the waveguide from 1-R-T as a reference. Then simulate it with the np, and calculate the 1-R-T again. the difference is the absorption. To have better result, please use the same mesh. eg, if the np is small and you need to use override mesh to resolve it, keep this override mesh when simulating the bare waveguide.2: use an analytical group to cover the np its self:
Please note that the analysis group is rectangle shaped. In case the other materials surrounding the np also have losses, and the analysis group covers part of them, you will need to modify the script in the analysis group, eg, to create a filter that only picks up the fields inside np.
I hope this helps.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2644
2110
1337
1112
461
