Auto-saving during Direct Optimization process
    • ciema
      Can we obtain auto-saving effect during optimization process? For example saving project after calculation complete for each design point?n
    • Dragana Jandric
      Is the concern that the solved DPs will be lost if the DX crashes? All solved DPs are saved in the memory automaticallynnIf the project was saved with a DX system in the Schematic before the crash:nThe simplest way to recover the DPs is:nRe-open the projectnA dialog box appears. Question is: Do you want to return to the last saved project version?n=> Click No (to keep all files that were generated between the last save and the crash)n=> An informational message says that all DPs were restored in the DX cache (internal memory).nRe-run your DX system with all the same settings as beforen=> The optimization is re-run but the DPs are not re-solved. They are immediately restored.nnn
