We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
LS Dyna
LS Dyna
Topics related to LS-DYNA, Autodyn, Explicit STR and more.
Autodyn impulse
    • Centurion_2020
      Hello,nI was trying to model explosion and obtained P(t) curve via Gauge point. Now, I would like to get impulse result for that P(t) curve. In the History menu when you make P(t) curve there is an option INTEGRATE bellow. I guess it is here for impulse calculation, but I usually get bad results. How to get accurate reading of impulse for particular P(t) curve since when I do INTEGRATE, I get another curve?n
    • Centurion_2020
      n
    • Missy Ji
       You can create the pressure impulse by clicking on the box Integrate after plotting the time history of pressure at a gauge point. What do you mean bad results?n
    • Chris Quan
      You need to subtract atmospheric pressure from the pressure calculated before calculating the impulsen
    • Centurion_2020
      mji, please look at the upper two images. Lower image is integrated curve of the P(t). What exactly is impulse values on this curve, how can I read it exactly?.cxquan, how can I subtract atmospheric pressure in Autodyn on P(t) curve before calculating the impulse?.n
    • Chris Quan
      To get over-pressure by subtracting atmospheric pressure from the calculated pressure, you can either add atmospheric pressure to P-shift in the EOS or click on Write Text Output to export the data to Excel. Then in Excel to subtract the atm.n
    • Centurion_2020
      Thanks man, this was very helpful. nI was wondering if you know why there is a second peak behind initial peak over-pressure in autodyn? I am running free air-burst simulation, no reflection of any kind. Can this be solved by some initial setup before running simulation?nI am uploading an image of one example.nn
Viewing 6 reply threads
  • The topic ‘Autodyn impulse’ is closed to new replies.
