November 1, 2018 at 2:01 pm
November 1, 2018 at 3:45 pm
tsiriaks
Ansys EmployeeHi AlexL ,
If you start ANSYS with 'run as administrator' , does this make any differences ?
Thanks,
Win
November 1, 2018 at 4:32 pm
AlexL
SubscriberThank You, Win, but unfortunately it`s not work
November 1, 2018 at 5:53 pm
tsiriaks
I'm assuming you have tried opening those two files directly and they are open fine.
Have you used any other ANSYS software/tools (e.g., Mechanical-Static Structural, Fluent, CFX) ? If so, do you experience any issue ?
Do you have any install.err under C:Program FilesANSYS Student ?
When you installed the software, did you do the "run as administrator" ?
Thank you,
Win
November 1, 2018 at 7:44 pm
November 1, 2018 at 8:39 pm
tsiriaks
Ansys EmployeeHi AlexL,
Thank you for the info. Windows 10 x 64 is fine. But now I'm worried about the localization issue. We have seen a lot of issues with the localization. Can you try setting the default language of your computer to be English ?
https://www.windowscentral.com/how-properly-change-system-default-language-windows-10
Thank you,
Win
November 2, 2018 at 8:01 pm
November 2, 2018 at 8:05 pm
AlexL
SubscriberTsiriaks, could You tell me, do You have a 32-bit version of Ansys 18.2?
Maybe it will working better
November 2, 2018 at 8:14 pm
tsiriaks
We don't have 32-bit version of Ansys 18.2. I think it's been retired may be more than 6 years now, since all (or almost all) OS are now running 64-bit.
Can you post the screenshot of the output of 'set' command (without quote ' ') from the CMD Prompt ?
Thank you,
Win
November 2, 2018 at 8:33 pm
November 2, 2018 at 9:40 pm
tsiriaks
Ansys EmployeeCan you include the part after this too ?
Thanks,
Win
November 4, 2018 at 2:21 pm
November 5, 2018 at 6:18 pm
tsiriaks
Ansys EmployeeCan you try reordering your Path environment variable so that the
C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem
are in front of any other paths ? See this instructions if you need help modifying the environment variable
https://www.java.com/en/download/help/path.xml
Make sure you make a copy of the original order in case something is messed up while you are changing the order.
Thanks,
Win
November 5, 2018 at 6:50 pm
November 5, 2018 at 7:02 pm
tsiriaks
Ansys Employee -
November 5, 2018 at 7:20 pm
November 5, 2018 at 7:50 pm
tsiriaks
I think you set it correctly.
Can you leave this setting like this, then change your default language back to English and reboot the machine. After that, open up CMD Prompt , then issue the following command (copy and paste the entire line)
move %appdata%ansys %appdata%ansys.back
Now try using AutoDyn again.
Thank you,
Win
November 5, 2018 at 8:53 pm
November 6, 2018 at 12:37 am
tsiriaks
Don't run that command under admin CMD Prompt. Run with a regular (user) CMD Prompt.
Thanks,
Win
November 8, 2018 at 9:09 pm
AlexL
SubscriberThank You, Tsiriaks, for yours help.
I`m use virtual machine with windows 10 and now it working. But it not working with real computer.
November 9, 2018 at 1:26 am
tsiriaks
Thank you for the info and sharing your resolution.
Something on the systems of the host (real) machine is not good.
Thanks,
Win
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1345
1118
461
