Automatic generation of csv files in Fluent
    • alimjalled
      Hello Everyone,
      I am running parametric simulation in Workbench. I prepared many design points and I want to save the curves of the variation of the surface heat transfer coefficient at the walls for every design point as .csv file without doing it manually. How can I do this ?
      Thank you
    • DrAmine
      Either automatic export in local dp directory or in global directory but here you might need to access dp number to avoid things been overwritten.
    • DrAmine
      Same can be done with CFD Post plus a session file.
    • alimjalled
      Thank you so much for your reply. How can make automatic export in local dp directory in Fluent ?
    • DrAmine
      You might ry the Automatic Export capability in Fluent and use "local" path for the directory. You need to keep the DP's data (retain).
Viewing 4 reply threads
