Preprocessing
Preprocessing
Automatic mesh refinement
    • tyw7
      Is there a way to limit Fluent from performing excess mesh refinement? I want it to refine my model 2 times and then stop.nnThis way I can submit to the HPC and I can compare the results.n
    • Keyur Kanade
      Are you using Fluent or Fluent meshing?nIn Fluent you need to use Adapt option. There is no direct option to limit cell count in Fluent. Please check following for more information. nnIn Fluent Meshing you can give limit. It is in TUI under mesh. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • tyw7
      Fluent through workbench.n
      On the Adaption panel(s) there should be a max level of refinement, set that as 2. n
    • tyw7
      OK thanks. So if I set it 3, it will refine 3 times and then stop?n
Viewing 4 reply threads
