Automatically switched to run in parallel -t1 mode
    • Anadi_Mondal
      Hello,nGreetings! When I am compiling my UDF , I am getting this warning-n WARNING: Automatically switched to run in parallel -t1 mode. **n** Detected non-parallelized UDF usage, enabling parallel usage. **n** If you encounter any issues, please re-run with -t0 flag. **nThen it compiled UDF successfully but while I am trying for initialization I am getting this error-n999999: mpt_accept: error: accept failed: No errornn999999: mpt_accept: error: accept failed: No errorn......................................................................................n==============================================================================Node 0: Process 2864: Received signal SIGSEGV.nn==============================================================================n999999: mpt_accept: error: accept failed: No errornn999999: mpt_accept: error: accept failed: MPI Application rank 0 exited before MPI_Finalize() with status 2n The fl process could not be started.nnWhat is the reason behind this? How to solve this issue?nI am using UDMI,EWF,DPM in UDF.nnThank YounAnadin
    • Keyur Kanade
      It looks like you are running Fluent in parallel. So udf is giving that message. nIf you are uisng UDM, please make sure that you you assign UDM before compiling UDF. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
