June 8, 2020 at 2:21 pm
June 15, 2020 at 12:39 pm
VivekKamble
Ansys EmployeeHello,
You can use a calculator in Maxwell
Go to Field Overlays > right Click > Calculator
Select parameters such as quantity, Geometry, Magnitude.
it seems the expression you are using to calculate the average B is not correct. -
June 22, 2020 at 9:27 pm
icellb
SubscriberHi, johnfides,
I guess you've already used the field calculator.
But I think it's Integrate(Volume(X),mag_B) divided by volume(X). Also, B is the flux density, do you actually want to calculate B or H (magnetic field)?
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1865
1272
610
