Discovery Import
Discovery Import
Average Pressure Drop Live or Discovery 2020R2
    • tim.dukes
      Hi Support,
      Is it possible to place measurement markers on the graph output for pressure drop. I would like to know the average value? The graph gives me real time data and I can move the vertical line along the time line to see the pressure drop at a given point in time, but not the average over a time period.
      Customer using Discovery Live 2020R2 and Discovery.  Discovery Standard Live and SpaceClaim
    • Naresh Patre
      Hello Tim Dukes
      You can enable Time-averaged result display and measure the values on the chart.
      • Andrew Stankovich
        Tim ,
        I just wanted to add when you create a calculator like pressure drop you can left click and drag in the chart area to get the statistics of the chart data. See in the image below.
    • tim.dukes
      Hi All,
      Thanks for the suggestions that's done the trick.
      Tim
