October 30, 2018 at 3:22 pm
MRMR
SubscriberHi
I'm analysing a flow through a nozzle in 3D in Fluent. I'm wondering, is there a possibility to create a xy chart, where and X-axis is distance (basic - X) and Y-axis is an average temperature. Normally when I try XY-scatter and I choose temperature for Y-axis I got many points representing temperatures in a whole cross-section.
Regards -
October 30, 2018 at 3:32 pm
Kevin Colburn
Ansys EmployeeYou can compute such a graph with EnSight. You'd follow this rough outline:
a. Create a Clip in X.
b. Compute average temperature on that Clip.
c. Use the "Query Constant on Part Sweep". This would generate an xy query (graph) of the value computed in (b), as you sweep (a) from some X location to some new X location.
There is a short video tutorial on this in the Customer Portal area here : https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge%20Resources/Solutions/Ensight/2055483
-Kevin
October 30, 2018 at 3:33 pm
MRMR
SubscriberIs a Customer Portal available for students?
October 30, 2018 at 3:47 pm
MRMR
SubscriberAnd is EnSight available for students?
October 30, 2018 at 7:47 pm
DrAmine
Ansys EmployeeUnfortunately Ensight is not available within ANSYS Students. Students do not have access to the customer portal.
The Ensight solution is a smart one.
You can indeed create that Chart inside Fluent and CFD-Post. But what do you mean under averaged temperature: is the average over the time or over the cross section? If it is an average over the circumferential then please have a look into XY Plots of Circumferential Averages
October 30, 2018 at 8:51 pm
MRMR
SubscriberI mean an average of a cross section - thank you for answers. Regards
October 31, 2018 at 2:54 am
Keyur Kanade
Ansys EmployeeHello,
You can use XY Plot feature in Fluent. There are predefined variables which you can plot.
You can also create custom field function which can be further used in XY plot.
Keyur
October 31, 2018 at 7:46 am
MRMR
SubscriberIn basic XY plot I have temperature, but while modeling a 3d nozzle on a chart I have too many points and my target is to get an XY chart where Y is the average temperature in every cross-section and X is distance.
October 31, 2018 at 12:08 pm
MRMR
SubscriberRight now I've found a possibility to create cross sections and calculate for each and average temperature. It's a kind of solution, but it will take much time.
2614
2088
1321
1108
459
