Preprocessing
Preprocessing
Avoid 1/8 octree transition
    • ahmedshafie
      If i choose yes, it will avoid it . Will it become more accurate and better mesh quality ?n
    • Keyur Kanade
      Which tool you are using? Can you upload images of the mesh with both options. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • ahmedshafie
      thanks for your reply . Its here in fluent meshingn
    • ahmedshafie
      if i choose yes for avoiding . It will be like this nn
    • Keyur Kanade
      This new mesh technology where mesh is connected. Yes, it is good to have it as it removes necessity of having hanging nodes in the mesh. nThe accuracy will depend on many other parameters as well. Keeping those parameters constant and having poly hexcore will give you good results. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • ahmedshafie
      thanks for your answern
Viewing 5 reply threads
