February 8, 2021 at 3:35 pm
foXSers
SubscriberHello, I have a ready-made Transient structural bearing simulation.nI am interested in the question, how can I get the results of the displacement of the center point of the inner ring of the bearing.n -
February 10, 2021 at 1:40 pm
Aniket
Ansys EmployeeAre you ok running it again? If yes, create a flexible joint (body to the ground) scoped to inner ring face and check displacements on the center point using the joint probe.nIf you are not ok running it again, maybe select all the nodes and check the average displacement, but not sure if that can serve the purpose in all cases.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn -
February 10, 2021 at 3:15 pm
foXSers
SubscriberThank you very much, Guru. You helped me a lot.n
3311
2471
