Axisymmetric Consideration for UDS
    • puh69
      I've developed a UDS using C code. It works fine with Planar conditions, in which I use a Poisson solver to recover pressure. However, when I attempt to use this in Axisymmetric flow I do not get the desired output!  I can walk through the implementation in detail :)
      Thanks
      Maybe post what you're getting and what you expect to get.
