March 3, 2022 at 5:40 pm
jailopez
SubscriberHello everyone
I am having a bit of trouble when setting core lossses to Hysteresis and using the BH curve of a magnetic material.
First, I tried simulating, in the transient simulator, the losses of a transformer, using a material with a nonlinear permeability and core losses set as ferrite, and everything went smoothly.
This is the BH curve for the material:
March 9, 2022 at 2:55 pmDeyu Li
Ansys Employeewhen you use hysteresis model with normal BH curve, starts from (0,0), the solver will solve the entire hysteresis loop not just the DC BH curve. There are some settings we will suggest:
Set Core loss (excitation) off on the object having core loss material
Refine mesh
reduce nonlinear residual to 1e-6 in analysis setup
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
