June 21, 2022 at 8:54 pm
Shiva2810
SubscriberHello
I am working on the demagnetization topic. To implement the partial demagnetization in the simulation, I changed the BH curve of one magnet.
Then, I did the no-load test on both healthy and faulty models. RMS value of back-emf of faulty is lower than the healthy model which is correct.
But, the three-phase back-emf after partial demagnetization is still balanced, and there are no new harmonics.
So, just like the attached figure I want to plot the back-emf od one single slot. I am not able to plot this signal in the results.
Could you please help?Thanks
June 29, 2022 at 2:17 pm
GLUO
Ansys EmployeeHi @Shiva2810,
The figure you mentioned is missing. Could you let me know what type of excitation you are using?
Thanks,
GLUO
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
594
