September 8, 2023 at 5:06 pm
bv169
SubscriberHello,
I am running an open channel multiphase model. When any backflow enters the outlet, the model crashes as there is divergence in the residuals. I finally figured out it is due to the wrong phase entering as backflow. Is there a way to control this? or turn off backflow?
Thanks,
Breanna
September 11, 2023 at 1:40 pm
SRP
Ansys EmployeeHi,
In the boundary condition, you can set the volume fraction for the backflow.
You can check fluent user manual for more detail: 25.2. Steps for Using a Multiphase Model (ansys.com)
Thank you.
September 11, 2023 at 1:46 pm
Ansys EmployeeIf you look in the phase options in the outlet you'll find what you're looking for. However, if you're using Open Channel VOF you should find options to set the free surface level.
September 11, 2023 at 4:04 pm
bv169
SubscriberYes, I am setting the free surface level at the inlet and outlet. Despite that it seems my phase from above that level is entering as backflow below that level. When open channel is turned on, I don't see the option to set the volume fraction for backflow...
September 11, 2023 at 4:17 pm
Ansys EmployeeIt shouldn't unless you have another boundary that's not been set? Pictures will help us as we're guessing at present.
September 11, 2023 at 6:05 pm
September 12, 2023 at 12:11 pm
Ansys EmployeeIf you're using open channel why is the domain full of water? The second image looks to be a diverged result so not overly diagnostic.
September 12, 2023 at 1:37 pm
bv169
SubscriberThe domain isn't completely full, but it is mostly full. The air phase is only about 5 meters at the top of the domain. Thanks for the info regarding the contour, I can try to evaluate where the divergence in vof is coming from before it gives the error to get a better diagnosis of the issue.
September 12, 2023 at 2:06 pm
Ansys EmployeeWhat did you set on the top boundary as the backflow phase?
September 12, 2023 at 2:44 pm
bv169
SubscriberThe top was set to a wall in this run. I just looked into changing the top boundary to an outlet/outflow and don't see the volume fraction option in any of the boundary types.
September 12, 2023 at 2:56 pm
Ansys EmployeePressure outlet - there should be a phase option. Do NOT use outflow, it's an old boundary and isn't recommended for use in most cases.
7592
4440
2953
1427
1322
