backflow total temperature
    • chayma
      i have the inlet temperature 1132 K what shoud i put on the backflow total temperature on outlet (pressure outlet)? it is the same temperature ?
    • RK
      It does not affect your solution, you can use an estimated guess. The backflow conditions come into picture when there is reversed flow. So, I would say take an educated guess and use a value just in case there is a temporary scenario of reversed flow.
