Backstress in usercreep.f subroutine
    • f_forndran
      I am currently working on implementing an own developed creep model using the usercreep.f subroutine. In addition, the material in question is modeled with non-linear kinematic hardening according to the Chaboche model. This plastic model uses a backstress tensor the calculate the translation of the yield surface and now I would like to know if I could access this backstress tensor inside the routine.
      The routine is already using the following function to get the stress tensor
      call get_ElmData ('SIG', elemId,kDInPt, ncompgt, sig).
      Is there a similar possibility for the components of the backstress?
      Any help is much appreciated!
      Kind regards
      Freerik
    • David Weed
      Hello Freerik,
      You may consider storing the back stress in a state variable. That way, you are not constrained by what the subroutines may/may not offer.
      Alternatively, see the ElemGetMat routine. It has variable storage for back stress: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_prog/Hlp_P_UPFNEWEL.html
      This subroutine is technically for a user-defined element, but it may work for pre-existing elements.
    • f_forndran
      Hello David,
      thank you very much for your reply and your suggestions. I decided to calculate the backstress within the usercreep routine and store it and not to implement the ElemGetMat routine.
      Kind regards
      Freerik
