TAGGED: -fillet-radius, equivalent-stress, Fillet, meshing, shaft
August 11, 2023 at 12:14 pm
Durgesh Pandey
SubscriberHello,
I have been trying this problem for months now and am pretty desperate to get solved.
I am doing a stress analysis in the geared shaft for my thesis project and the stress result I am getting on the shaft shoulder(red circled) is much higher than I expect. I get good range results when I remove the fillet from the shaft shoulder but part of my analysis is to see the difference in result with a bigger size of the fillet.
I have tried so many ways to make different meshes and obtain good results but I can not just do it. Please please help!
August 11, 2023 at 7:44 pm
Armin_A
SubscriberHi Durgesh,
Is there a fillet in your model in the region indicated by the red circle? The element size may be too coarse to capture deformation of such a tight fillet. If you're seeing stress values that you believe are un-realistic (for example, artificially high), please check the video below where the causes and remedies for this problem is discussed in more detail:
Understanding and Dealing with Artificially High Stresses — Lesson 3 - ANSYS Innovation Courses -
August 12, 2023 at 10:38 am
Durgesh Pandey
SubscriberYes, this is the fillet in concern. There are a couple more fillets but they have more believable results.I tried to play with a lot of options including suggestions shown in the video. Unfortunately, it did not help.
The fact I want to compare the effect of a bigger size of the fillet is essential for me to include. I am super desperate to find some trick to get good results in such a fillet area!
Please help!!
4502
2959
1449
1322
