November 20, 2023 at 2:53 am
Yiqing zhang
SubscriberI am calculating a two-phase water vapor flow problem in an open channel, using the VOF model. The error "BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES" is accompanied by "The fl process could not be. This error occurred after I had calculated many steps. After it appeared, all the buttons on the fluent interface could not be used. After I restarted the calculation, the same error was displayed again. How to solve it? I used 2022R1
November 20, 2023 at 1:23 pm
Federico Alzamora Previtali
Ansys EmployeeOnce this error is thrown, your Fluent session will be corrupted and will need to start a new one.
Does the error always occur at the same iteration? Try to see what happens with your solution before this error is thrown.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
