August 12, 2019 at 4:59 pm
Subscriber@krndv, please reply with some images inserted into your post of the geometry and the mesh.
August 13, 2019 at 9:17 am
Ansys EmployeeMake sure you create a named selection on the walls, they may still be present in Fluent but you'll need to guess which interior zone it is: labelling is better.
Edit: I'll move to a unique thread too.
krndv
SubscriberHello,
I am modelling a mixing tank with an impeller and a baffle. The baffle and impeller i modelled as thin surface with zero thickness, but after meshing when its transferred to fluent the internal baffle and turbine disappears.
Meshed using ansys Meshing.
How to solve this?
August 13, 2019 at 4:52 pm
krndv
SubscriberHello,
I am trying to mesh a tank with a baffle inside (Simulating a 60 degree sector of tank with periodic BC).
Tried meshing and did named selection of interior baffle (Thin) from Ansys meshing module but the baffle was not showing in fluent. I solved this by naming the baffle from DM itself and baffle and tank was made in to single part, this worked and baffle showed in fluent anlong with a new boundary 'baffle-shadow'.
How to handle 'Baffle-shadow'? keep it with default conditions or give same conditions as orginal baffle?
August 14, 2019 at 12:41 pm
Ansys EmployeeWhen you have a thin wall you need a boundary definition for both sides (mainly for roughness). It's explained in the User's Guide. Assuming it's not also a heating unit leave the settings alone for the wall & wall:shadow pair.
August 18, 2019 at 5:23 pm
krndv
Thank you @rwoolhou.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2064
1279
1096
456
