June 28, 2020 at 3:18 pm
HritikJain
SubscriberHey, I am getting an error while running the transient analysis. The error is as shown in the image. Initially I didnt got such error. But the solution I got was unconverged, probably due to bad meshing. So I simplified the geometry by simplifying the CADS and by combining to or more CADs.
June 28, 2020 at 3:19 pm
June 28, 2020 at 3:51 pm
SubscriberIn Workbench, drag and drop a Modal analysis onto the Model cell of this Transient Structural analysis. In Mechanical, drag all supports from the Transient analysis and drop them on the Modal analysis. Solve the Modal analysis. Look at the first 6 mode shape displacements. Look for a part that is not connected.
June 28, 2020 at 5:21 pm
HritikJain
SubscriberBut that is not the results that I want. I am not getting you? Why do I have to use Modal analysis in this case?
June 28, 2020 at 5:23 pm
HritikJain
SubscriberNow I did some changes in mesh so I have only got the displacement till now. But I haven't got the stress results. The solution is also unconverged. Also the displacement is kinda wierd.
June 28, 2020 at 5:38 pm
SubscriberYou showed an error that an internal solution magnitude limit was exceeded. That means something is not connected in your model. You have to fix that. Do you know what is not connected? If not, a Modal analysis will show you what is not connected because that component will float freely in the Modal solution.
June 28, 2020 at 5:54 pm
June 28, 2020 at 7:45 pm
SubscriberDo you mean the two parts in the top half of this image?
I assume these two cylinders are supposed to be concentric and slide along their common axis.
Delete the contact and under the Connections folder Insert > Joint > Cylindrical.
Do you have a spring-damper defined along this axis?
June 29, 2020 at 3:25 pm
HritikJain
Subscriberyes, I have defined the damper and spring.
3850
2629
1853
1246
600
