January 23, 2021 at 3:38 am
bozheng
SubscriberDear Sir/Madam,
I use explicit dynamics to simulate the U tunnel. The contact is frictionless, the bottom is fixed, the initial velocity is 3m/s, the end time is 1s, total length is 3m. But the ball could not pass through the curve, can you help to find the problem? Thank you!
Bo
January 29, 2021 at 12:33 pmAshish Khemka
Ansys EmployeennCan you please share a snapshot of the results? Also, can you share snapshots of the setup?.Regards,nAshish KhemkanJanuary 29, 2021 at 5:29 pmbozheng
SubscriberFebruary 1, 2021 at 7:36 amAshish Khemka
Ansys EmployeennCan you try improving the mesh near the bent and then check the result? By the way, you may use a transient analysis as well. We suggest an Explicit analysis for simulating scenarios occurring in a fraction of second.nnRegards,nAshish KhemkaFebruary 2, 2021 at 5:42 ambozheng
SubscriberHello Ashish,nThanks for your reply. I will try.nBestnBonFebruary 8, 2021 at 11:28 pmViewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5364
3355
2471
1310
1018
