February 16, 2022 at 12:00 am
HRK
SubscriberI am trying to analyze eye pettern through Mach-Zehnder modulator, but in the property pannel I could not see any variable for bandwidth of it.
Do anyone help me how to configurate bandwidth of this element?
February 23, 2022 at 7:01 pmGuanhui Wang
Ansys EmployeeHi HRK How do you define the bandwidth of the eye diagram? Or do you mean the 3-dB bandwidth for the modulator? To calculate the modulator S21 bandwidth, you can use the same method we introduced in this exmple here: https://support.lumerical.com/hc/en-us/articles/360042329094-Ring-modulator-time-domain-INTERCONNECT-
- Error on Lumerical device
2532
2066
1285
1104
459
