Base Excitation in Harmonic Analysis
    • krishnateja.garrepally
      I am doing a base excitation using Harmonic Analysis.
      I gave 20-20000Hz, used the Modal analysis supernode method for simulation and called the same in Harmonic Analysis. The structure is a simple hollow plastic box kept on a plate. This plate has 4 holes on the 4 corners, where I want to give an acceln of 5g. But if I use the acceln option, it applies to the whole body.
      So either you can recommend a way to apply acceln on these 4 points and not the whole body or guide me with another way to do the same effect on these 4 holes.
    • Erik Kostson
      So we need a Modal analysis connected fully to a Harmonic so that we use the MOdal Super Position Method for Harmonic analysis
      Under the Acceleration boundary condition object, there is a Base Excitation Setting under definitions which we can set to Yes and apply say to the fixed support.
      (see our course for more details:
