June 15, 2022 at 7:07 pm
evelyn.ferwalt
SubscriberWhenever I run my code to create the geometry for my big ring resonator in Lumerical 2021 R2.4 FDTD (and I think also MODE) it gives me this nasty popup exactly four times:
Which is reproducable even when stripped down to the bare essentials:
addobject("ring_resonator");
set("radius", 300e-6);
set("base width", 10e-6);
And I suppose I understand what it's warning me about, but a 10μm wide waveguide isn't exactly huge compared to a 300μm radius. I know this because after I dismiss these warnings, all I need to do is right click on the ring resonator structure, then hit "ok", and it rebuilds the geometry with the correct width no problem.
Is this a scripting-only limitation? Am I doing something wrong? Any help would be greatly appreciated. -
June 15, 2022 at 8:42 pm
evelyn.ferwalt
SubscriberSorry, to be clear that's
right click -> edit object -
June 16, 2022 at 6:54 pm
Guilin Sun
Ansys EmployeeIt is just a warining message.
You can avoid it by addring and addrect respectively and assign their parameters.
- Error on Lumerical device
3930
2649
1863
1272
610
