Battery model – Virtual battery connection issue
    • Maurizio Porcaro
       I am trying  to use the “use Virtual  Battery Connection” option in battery model . I used the tab surface-based format.
      I have defined with the named selection solid all the cell & the tabs and I  have defined the surface as shown in image.
      When I enter the filename containing the virtual connection in Fluent, it show in console this message:
      “Error: Tab Zone of battery 1P1S is not connected to the positive tab. Please fix it before proceed!”
      Could you help me?
    • ali abbas
      when you did the name selection in the meshing interface, did you define the tab_n_(1,2,3,4) and tab_p_(1,2,3,4) as faces or bodies?
    • Maurizio Porcaro
      hi,
      I defined the faces highlighed in image below.
    • ali abbas
      Can you try please to put the tabs woth same signs all in the same row and not in opposite way
    • Maurizio Porcaro
      no because the supplier send us this battery package . The target is to simulate and testing the battery pack.
Viewing 4 reply threads
