Beam connection for internal thread
    • greg2835
      We're analyzing an assembly that has two threaded holes with screws. I'm used to using beam connections for bolted joints, but I don't think it works the same for internal threads. The J node is scoped to the hole surface, and the CEs project from that node to the surface, which isn't that realisitic. I wanted to ask if there are other means for doing thus short of including the screw models.
    • peteroznewman
      @greg2835
      Read this thread for an example of the next level of accuracy available.
      https://forum.ansys.com/forums/topic/simple-method-for-simulating-local-deformation-near-fastener-threads/
