August 22, 2019 at 4:24 pm
tumulpurwar
SubscriberI looked into importing a surface into SpaceClaim to use as a profile. I created a surface and saved that as a .scdoc file then tried to select that as a Beam Profile. The first error said a profile must have a Coordinate System and a Single Colored Face. I added a Coordinate System. Now the error message is a Profile must have a Single Colored Face. I don't know how to have the surface have a Single Colored Face.
Does anyone else know this?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2682
2120
1349
1136
461
