September 27, 2018 at 7:02 pm
Yazan Thaqakha
SubscriberHello,
I am using Modal in Ansys Workbench 19.0.
I have drawn a beam with a circular cross section, and set the constraint "fixed" on one end (on the surface).
After that I apply "Total deformation" in the solution section after that I solve it and produce the mode shapes and frequencies.
I have 2 questions; 1- I always get 2 similar frequencies in a row as shown in the picture below, why is that and how can I fix it?
2- When I play the mode shapes, the beam moves in 2 dimensions at a time, how can I fix it and let it move only in 1 dimension"
Note: When I draw a beam with rectangular cross section, when I play the mode shapes, the beam moves in 1 dimension only.
Thank you very much for the help! -
October 1, 2018 at 9:12 pm
Sandeep Medikonda
Ansys EmployeeHi Yazan,
It looks like you have a symmetric structure. When you do it is expected to have linear independent model shapes for identical frequencies. These are typically called degenerate modes and depending on the symmetry several frequencies can have this.
I am not sure what you mean by moving in 2-Dimensions? Isn't the mode shape dependent on the Eigen Vector? Can you alternatively just 2-D analysis? You can set this in the Properties tab in Workbench under Analysis Type.
Sandeep
Best Practices to post on the Student Community -
October 1, 2018 at 10:56 pm
SubscriberHi Yazan,
Your circular beam is symmetric, so you can eliminate the duplicate frequency results by splitting your geometry in half through the center of the beam and using a Symmetry Region. That way, your beam will stay in the plane.
2146
1357
1144
462
